- Jan 21, 2007
I have to admit, this is the first time I have heard of a Venice core on a s754 I thought Venice was strictly s939 I've Googled the numbers on it & even searched for it here in OCF but can't find anything on this particular chip (except AMD's site). When I saw it on NewEgg for $53 I thought I'd give it a go anyways.
Anyone ever heard of this one? If not, I'm surprised because it overclocks like a madman...
2.2GHz AMD A64 3200+ Venice (11x200MHz)
ADA3200AI04BX LFBBE
CPUz reports 90nm Stepping: 2 Revision: DH-E6
Now here is the kicker...this thing does 2.75GHz (11x250) @ only 1.45V on my ECS NF3-A board like it's nothing. 26 hours Prime & MemTest stable with 29C idle/47C load with my Zalman 7700Cu. The only reason I had to stop at 2.75GHz is because 250MHz is the fastest HT bus speed my mobo supports (gonna give ClockGen a round or two later). That's a 25% OC on air w/ only a 0.05V bump!
Oh, and if you're wondering about the 11x multi, this chip seems to be multi locked. I thought all A64 chips were downwards unlocked except the FX chips (which are fully unlocked)
Anyone have any info on this chip? If not, I'd grab one at only $53 if you still play around with s754 at all.
EDIT: Using Clockgen, 2.8GHz (11x255) seems to be my top 24h Prime stable speed but only because this PC2700 ValueRAM won't hold any more (MemTest craps out after 8 full passes). And if I bump it down to PC2100, I take a serious memory bandwidth hit...not worth it. May see what it will do with 2GB of some quality PC3200 or 3500.
ADA3200AI04BX LFBBE
