- Mar 26, 2002
- San Francisco
I see Golden Sample after Golden Sample getting way more out of it's memory than I am. I'm only getting 490 with my MX440, and it's rated at 500 from what I hear. Stock non Golden Sample memory is at 400. I don't know, maybe that's good for this card but I see others with the Goldens getting 500+ without heatsinks, you'd think I'd do better than that.
The reason I ask is that I used the Arctic Silver 3 and Krazy Glue method to apply. With all the warnings I've heard about AS3 briding pins on the memory, I was VERY stingy with it. I know less is more in the thermal grease issues, but the more I think about it the more I worry I used too little. See, memory chips aren't as smooth as a CPU core, they're rough plastic. Perhaps I'm not getting a good connection?
--Illah
--Illah
