I just bought one, the only problem seems to be when you have PC2700 running @ 333. It has a little quirk with this new chipset. Soltek is working to solve the problem. If you run the Memory @ 266 it runs fine. Stable xp 1800 @150fsb
I didnt end up buying this board,it is a good board from all the reviews I read,but for less money I went with the 8K3A+,but I have Kingmax 2700,should work well in both..I hope
Hmmm, I was going from my memory because I don't have the Soltek running anymore. I got in a copper block last week and tried to setup water cooling over the weekend. A hose fitting had a really small leak (more of a moist spot actually). Thank God that I was checking frequently nothing got wet. So this coming weekend I'm gonna take it down and re-do it.
Well I did end up buying this board also,and so far I am not impressed with it,with my CPU unlocked it dont seem to like the lower multipliers at all,runs well @ 11.5 or higher,but I like the multiplier low so I can up the FSB,but so far I have had no luck at all
Maybe you can look at mine also,im getting nowere with mine.
I got mine set @ 152X10,all normal settings on the ram.
IBM 60 Gig HD
GForce 2 Ultra
SB Live
3 Com Home connect Ethernet card
Antec 300 Watt PSU
All the reviews I read said this board was a Hot Rod
here is the scoop.
xp 1900+ locked (running win xp pro)
soltek sl-75vr5
mushkin pc2700 cl2.5
maxtor 7200 60gig ata133
radeon 8500 64meg
sb audigy
creative 52x cd / lg 32x cd-rw
bios
fsb freq 133
dram 166
dram clock 166
dram timing manual
dram cas 2.5
dram burst 4
dram queue 2 level
dram command 2t
system performace normal
vcore 1.8
dimm/clk auto detect disabled
fsb 143 (will boot at 144 but not stable if higher blue screen.
