Has anyone else had enermax 430 probs? Mine can't support the cpu at 1600 or higher...get reboots after that...even my old 300 watt could break 1600 by a bit...if you had prob did you replace or live with it? Just curious what other people decided...or if lots are having this prob...
I have two harddrives(can't power the third), a burner, a dvd, 3 case fans,soundblaster,firewire, nic,and geforce 3
Thanks
Thanks
