- Jun 19, 2001
I see many of you guys saying that your rigs are so D*MN loud, because you have something like 2*120mm fans, 4*80mm fans and a few 40 in the drive bays, two psu´s with fans, a HSF with a 7000rpm screeming fan and a pcibus card cooler! WHY?
You are overclocking, and your cpu, chipset and vid card is producing heat. So you add more fans, and yet you run your comp with the case off otherwise it overheats.
And then there are a few that reach almost the same overclocked speeds, with a minimum of fans and their case on.
Is there SOMETHING that makes some rigs so damn much hotter, or do some successful people just know something the rest of us don't?
Question:
Do we HAVE to have 500dB systems running 2000cfm and still run with the case off, or are we doing something so wrong?
Question:
