- Nov 28, 2001
- in a magical field
Were yours single or double-sided? I may have missed that in a previous post.
Did it ever occur to anyone that clocking DDR2-800 to 1000+ could kill it? I know all about the 'same chips' theory but binning exists too. Also it *seems* as if older sticks are still going strong versus some of the more recent sticks.
This is aside from the single-sided issue.
i wonder what keeps killing these ram sticks? i know it's not the ram module it's self... i have two sets of G.skill HZ 2x1 (PC6400 and PC8000) and i'm *pretty* sure they are both running the D9GMH module. on 680i they run 1T command rate very easy. i've never had a problem with them. the pc6400 set i have has been under a dominator cooler their whole life, but heat shouldnt be whats killing this stuff. maybe they F*ed up somewhere in the manufacturing process???
this is odd. Did the DDR1 versions of the ballistix have this same problem? i wasnt into overclocking back then and just had some best buy kingston stuff....
weird man, well, i got my stix yesterday (ballistix pc8500), and after reading this, i had to know fir sure.. mine are single sided, at this second, they are running 450x8 1:1 4-4-4-12 2.25v, my gskills only need 2.2 for that, but these need a lil more.. but.. i havent tried them on their own yet, ive just been running these and my gskills, wich are d9gct (nakid!) i just needed to bump my nb volts just a tad, but so far so good
When I got the E8400, I paired it with a 2GB set of ballistix pc8500. Needless to say, I ended up going through 2 RMAs and finally got the pair in my sig. My experience with the ballistix pc8500 is that they are the biggest P.O.S. memory sticks out there. They caused me weeks of downtime and more than $25 in RMA sending fees. The two pairs I had were both the single-sided ones, and they threw hundreds of memtest errors at even DDR-800 5-5-5-15 and 2.2V. They were not stable even below their spec. speed. I want nothing to do with Crucial again, and I highly discourage others from buying these sticks, as I know of many others who experienced simial problems.
by the way, right now i'm testing 2gb ocz plat rev 2s that are rated 4-4-4-15 @ 800mhz and i think it says 1.9-2.1vdimm. i'm trying 2.0vdimm and we'll see if it can prime overnight.
The majority of the complaints are about the single-sided stuff? Seems like a classic oc'ing 'revision debacle' when the supposedly same part is changed in some way and becaomes crap.
I have a pair of double sided DDR2-800 and a pair of single sided DDR2-800, running together, in a P5K Premium.
Of course, I do have a fan blowing on them for active cooling. Seems to help things alot more.
That said, they certainly shouldn't *need* a fan at stock settings, I understand that. But if it a $2-$3 fan allows them to work and run much cooler, also cooling surround objects, then why not do it?
