- Sep 7, 2002
- East Coast
Hi everyone, I need your help.
I have a 1400 Tbird, running at 1050MHz (yes, underclocked) on an Epox 8kt3a motherboard (133 fsb, 768mb pc133 sdram). The pc is old, but I'm having a hell of a time cooling it! So much so that I have to underclock to keep the system running
I have a Thermaltake Volcano 6cu HSF and using some generic paste on the cpu. The idle temp is 47c, as reported by MBM for the CPU. MBM shows the case temp to be 35c -- HUGE difference!
I have the case covers off! Obviously, something is wrong with my cooling. Do any of you have any suggestions for a new HSF? I used to have a delta fan on the cpu, but it was waaaaay too loud.
I heard you can use an 80mm fan instead of the 60mm fan on the heatsink?? Are 80mm fans better than 60mm? Are they quieter or louder?
of course, i want to run the cpu at full speed. can anyone please suggest a solution??
