- Jun 9, 2001
- Montreal, Quebec, Canada
Are you trying to plug this in on your front USB's? and have you tried plugging it into the rear USB's?
maxxoverclocker said:I had the same problem with my external hdd, what worked for me was in the device manager to right click "disable" (not uninstall) then unplug the hdd, restart the computer, then reconnect, that has worked every time for me. hope that helps
jajmon said:right click My Computer | Manage | Storage | Disk Managment - does it see it there? If so, what does it report? unknown etc
erics2one said:I've already returned the Maxtor drive.
Dascious said:I to am encountering a similar problem, I have changed my motherboard recently and now my USB key will not be recognized by XP SP2. I have tried similar things to what many have suggested here and none of them have worked. I to am confident it is not a power issue or windows lacking the correct drivers. I know the very drivers windows needs to use for it from the System32/driver folder, however windows looks for some form of install folder which I can't offer it and it does not allow me to tell it specifically what drivers to use (any suggestions).
I believe the problem is as was previously mentioned a confliction issue. Once again I am at a loss of how to resolve this issue.
I have several ICQ conflicts attributed to PCI slots shareing with others.
One thing occured to me is maybe if I was able to disable these devices which are sharing with my USB ports I might have more success.
I tried and still It failed, others I know have found success at this point, you might find it works for you.
My question is! Is it possible to change ICQ assignments, I've looked at my options in the bios and the assignment option is really very inflexable, it is all very automated.
All my USB devices share IRQ 21, will changeing the PCI slot of my USB card help?
