My 4 year old custom build works fine but am considering upgrading 1 or more components. My budget is $2000 Cdn and want my PC to stay relevant for at least another 5 years!
My work involves primarily 3D applications (Houdini, Maya, etc) and working in Unreal Engine.
This is my current build
Should I consider upgrading my CPU only? CPU + Motherboard or?
What would you recommend?
My water cooler seems to work fine but haven't changed coolant or done any maintenance since purchasing.
Should I make this a priority? ie if I don't ever clean and change coolant can I expect a performance decrease due less cooling performance?
Thanks!
- Motherboard ROG Zenith Extreme 399
- CPU AMD Ryzen Threadripper 1950X 16-Core Processor 3.40 GHz
- Water Cooler Swiftech H240
- GPU 2x Nvidia Volta
- RAM Total 64 GB
- EVGA 1200P power supply
Thanks!
