- Sep 26, 2002
- Indianapolis, IN
ok, i have a slight issue. i have the following setup:
windows xp pro - installed on my 2 x wd raptors in raid0 (sata)
solaris 10 - installed on a separate wd caviar 80 gb drive (pata)
i have been successful at booting from each drive when i select it via the BIOS primary boot device menu, but i can't get the bootloader of windows nor grub to load both. grub boots solaris just fine. ntldr loads windows xp fine. i would ideally like to have it so grub can load both windows xp and solaris as i like grub a little better to be honest and is a more powerful bootloader. the problem that i am running in to is getting grub to boot windows. it just sits there and i am assuming it is because of the raid 0 array. is this correct? if so, is there any way around it? i have done a couple hours of googling and trying things without any luck. if somebody could get my headed in the right direction, that would be great.
