Ello,
I am putting together a 1.4GHz Tbird system and I have a question about cooling. I have pretty much decided that I would like to cool my system with water but that is where I get a little lost. Because I have never done anything like this before, much less build a computer. So I'm kinda baptising myself in fire so to speak.
I like the products that Danger Den has but I am not too sure about how it all works. With other companies when you get/or make a kit you need a radiator to bring the heat out of the case etc. I was thinking of putting together my own kit from DD and using the MAZE2-2 copper block. It says that you can put a peltier in it between the block and the cold pad, but I am not sure about this. I looked on their pre-made kits and none of them had radiators, just pelts. On that note how does it work? Does the pelt cool off the water instead of a radiator? If this is sort of how it works does the case get hot at all? At this point I am totally confused, so if anyone can point me in the right direction or give me a tip I would like that.
Furthermore is Danger Den a good company to make a watercooling set from? I am all new to this so if anyone could elaborate on any of these points I would appreciate it a alot.
Thanks
-Julian
Thanks
-Julian
