wana know the best air cooling setup
a case with front and rear 120mm slots cut out the fan grills and have filter on the front
the case to do this i recomend is the Antec SLK3700BQE i use it it has a filtter with it.
get 4 vantec stealth 120mm put then like this:
1 front, 1 rear, 1 as a top blow hole, 1 side.
then go buy 1 panaflow 120mm and mount it on a XP 120.
on your north bridge use a zalmen fanless.
get a hardcano 12 put your HD in it and hook all your fans up to it bring the rpms down on the fans so that they are nice and quite (the hardcano 12 will let you adjust your fans), they will still be pushing lots of air but can run at lower rpms/ noise and still push the same amount of air as 80 or 92mm's.
then just get a fillter for your side 120mm (
www.ncix.com )
just the main thing is to remember this big fans= less rpm's= less noise (yet still lots of CMF's) good fans panaflow, silent X , and vanteck stealth.
