youngbuck said:My case has only 1 slot for a case fan. Then I have my PSU which exausts directly above the case fan slot. Does anyone know what my PSU might exaust out in CFM? I have an Enermax 350W PSU.
Is what I'm thinking of doing, for the time being, is just having the PSU exaust, and have a rear case fan intake. I know it won't be nearly as affective as things should be, but I guess it's my best bet. (?) Then, depending on what temperatures are like, I may or may not add a 5.25" front bay fan (intake). That way I'll I'll have better airflow rom one end to the other.
I wish I had a dremel tool to cut some slots in myself
PS you could always cut a few fan holes in the side or top of your case if so go with 120mm / 12cm fans at lower rps to keep the sound downStedeman said:
In this situation you would want to exhaust with the case fan because of its location to the psu fans
1) if you where to blow in it would loop right in to the psu
2) and vise versa suck in the psu’s hot air being blown out
3) if you exhaust with the case fan it will draw more air in from the front of your case (make sure you have enough air inlets in the front of your case if not use a dremal or drill and make some)
ChillPhatCat said:A COUPLE QUESTIONS, FEEL FREE TO SKIP TO HERE:
Is it a good idea to have multiple exhaust locations? Like one on top, one in front and one in the back? Or is this too disruptive for the airflow?I have a dremel and I am not afraid to use it!
Originally posted by ChillPhatCat
If I was able to only have 1 case fan, and 1 case fan only, would it be better in the exaust or intake position?
Originally posted by Lusankya
I am goign to mount 2 80mm's in the bottom front side of my case for intake to get some positive pressure.. if this dosen't work.. I'm geting a new case and going H2Oh yea
This is a half truth you could have no inlet fans and still do ok as long as you had enough free flow in the correct spots ( 2-3 X 3" tunnel rams one to the inlet of the cpu and one across the pcis would work well also *if done right)h0mersimps0n said:I read this on the forums here once and it makes a LOT of sense to me, I suggest you try to stick to this reasoning:
RULE OF THUMB:
Keey total CFM IN greater than total CFM OUT...
reason, and #1 killer of mechanial fans, DUST. If you have more air blowing in, air will blow out through all cracks and spaces. If you have more air blowing out then air will get sucked in through the cracks and settle on your hardware.
I always try to keep my cfm IN 20cfm greater than OUT...
good luck.
