- Mar 9, 2003
So, I am very experienced computer builder. Ive worked as a network tech, built countless computers for others and my own and dealt with any problems imaginable... and i am stumped.
athlon 64 3200+
DFI Lanparty NF4 ultra-d
2x512 OCZ platinum rev2 (pc3200)
geforce 6800gt (pci-e)
raptor 74gb 10k rpm (sata)
wd caviar 200gb 7200 (ide 0)
dvd rom (ide 1)
Heres the deal, my computer had been running a bit slow so I downloaded the newest gfx drivers and while they were installing the power went out. I rebooted and I got a weird graphics error. Long story short, I gave up and reformatted my computer. Before the format i was running two (2) harddrives a WD raptor 74gb (sata) and a WD 200gb caviar. There were two (2) primary partions on the raptor (1 windows 1 games) and the entire 200gb hdd was for data.
So, i reformat. I wipe the 74gb clean, make a 30gb partition and install windows. Everything goes alright, installs fine. I reconnect the data disk after, and instead of the Windows loading bar taking 4 seconds on start up, it goes all the way up to hanging there for 1 minute plus. Ok, maybe a faulty install, I wipe it and install again. Same deal. But if I disconnect the data hdd (200gb) and the dvd rom it boots up as quickly as ever. Now this is JUST during boot up, once its loaded everything works great.
So, because it is just boot up I got about my troubleshooting:
1) check jumper settings
sata - 74gb
ide0 - 200gb hd (jumper on CS)
ide1 - dvd rw (jumper set on CS, i think)
--- these seem to check out, not fighting for boot priority or forcing a master drive. Also these were UNCHANGED from how it was before my power outage mishap and everything worked great then
2) Check the CMOS.
-clear cmos: nothing
-update/flash cmos: nothing
-check cmos settings for quick boot, boot disk priority etc: nothing
3) Now i get a little more desperate, i try all combinations of drives plugged in. With ANY other drive than the main 74gb windows hdd it runs slow, when its all alone its like lightning.
4) I try installing windows on some old HDDs to test if its just my 74gb being a problem, windows doesn't seem to want to install on them and gives me disk errors on two seperate harddrives that previously worked. (no idea why the installs didn't take)
At this point i am lost. It doesn't feel like there is a problem identifying the drive to boot to, as it gets to the windows loading screen very quickly. But once on the windows loading bar screen, it takes INCREDIBLY long, (3 scrolls normally, 40+ with other drives attached). If the drives amazing hooked up alone, how could it be a problem with the drive?
Any ideas? i appreciate the help.
athlon 64 3200+
dvd rom (ide 1)
sata - 74gb
2) Check the CMOS.
