- Sep 30, 2002
- Oregon
Here is my system in all it's unassempled glory tell me what you guys think so far?
*Uptaded*
My system <--56k beware
I checked everything for clearance, and it fits over my tallest card - ti4600 - with about 2mm to spare. The only thing I am going to have an issue with is routing my hose so it doesn't kink, the block is literally right under the top of the rad, and no hose (even tygon) can go that tight without crimping. any suggestions on that? I've heard of people putting a spring in it and boiling it, then bending the tubing to the position desired, then leting it cool. does this work?
I have a Maxi-Jet 1200 powering it, submerged in the res with the output poking out the hole in the middle. I am making a switch for the pump on my other blank, along with a light dimmer for the 10" fan I am getting on monday .
Should I have the rad before or after the block?
and yes, I am going to comb it before I get it running .
*Uptaded*
