For the longest time i've been wanting to buy this case: http://www.svc.com/clearaccasat.html but i'm a little stumped on one small problem. I'm planning on buying a water cooled system, and i was going to use the radiator from Dtek. All the fan mounts in the case are for 80 mm fans; what i was wondering is if anyone that has this case could tell me if i could enlarge the front intake fan to fit a 120 mm fan without it getting in the way of anything. If not, where would be a better place to cut a hole and place the radiator and fan.
Another minor question is if a 400w psu can sufficiently run an amd 2100 that's oc with all the fans and lights..
