Newguy123 (Apr 25, 2001 09:52 p.m.):
But the manual usually says how to adjust the multiplyers to what position on or off. and this one only has 1-4 it tell u what to do with. But there is 1-10 on the dip switch and i dont know how to change the multiplyer on the asus a7a.
On the motherboard it only goes up to 12.0x Multiplyer is there a way to put it up to 13.5x? Or do i just put it up to 12.0x and then just up the FSB ??
I just need help on how to adjust the Mutiplyer because it wont let me highlight that option in bios?
Thanks for any advice
Newguy123
