- Nov 6, 2004
In and effort to help all owners/prospective buyers of the MSI K8N Neo2 Platinum board, I am posting my most current stable OC settings... Feel free to join in and post your rig and it's stable OC settings!
Pics of my rig can be found
HERE --> http://thematrix.homelinux.com/Pix/pix.html
MOBO: DUH! Bios Version Beta 1.51
CPU: AMD Athlon FX53 Stepping A REV. SH7-CG WC'd by lapped dangerden RBX Artic Silver 5
Memory: OCZ 3200 Platinum Rev2 2x512 2-2-2-5 in slot 1&2
Video Card: Ati Radeon x800 XT PE shim removed & WC'd by lapped D-tek GPU block Artic silver 3 & Lapped ramsinks added to all 8 GDDR3 chips.
HDD: WD Raptor 74Gb on SATA port 3
Sound Card: Soundblaster Audigy 2
Power Supply: Antec Truepower 550
Case: lian-li PC65
Radiator: danger den Double Heater Core cooled by 120mm panaflow
Reservoir: custom res....
Pump: Eheim 1250 @ 318Gph
N-force is cooled by lapped vantec copper orb
Coolant = Distilled water + water wetter + green dye-lite
BIOS VERSION = Beta1.51
Cell Menu-->
Memory Submenu --> Auto, 1T, 2.5, 3, 5, 3
Cell Menu-> shift+F2 then Alt+F3 -->
Hiperf = manual
agp drive = disabled
speedup = disable
Dram Strength = normal
spread-spec = disabled
HTT = 4x
Mult = 10.5x
FSB = 253
agp = 66
vcore = 1.55
vid = 3.3%
vdimm = 2.75
agp =1.65
My radeon is clocked @ 560/572
Case: lian-li PC65
Cell Menu-->
Hiperf = manual
speedup = disable
HTT = 4x
Mult = 10.5x
FSB = 253
agp = 66
vcore = 1.55
vid = 3.3%
vdimm = 2.75
agp =1.65
