- Nov 2, 2007
Hey folks!
I did a quick search, and found a ton of threads about both the MSI K8N NEO 2 Platinum, and AMD processors. However. I really need a "HOW TO OC FOR DUMMIES" guide it seems.. because im not able to OC it
My equipment is:
-MSI K8N NEO2 PLATINUM 54G (AGP)
-AMD 3000 (1.8ghz) WINCHESTER
-Geil 512MB DDR PC3200 400MHz Value CL2.5 5ns Aluminum Heat Spreader 2.5-2.8V x 4 (I have 2gb ram)
More info about the GEIL memory:
# Aluminum Heat Spreader
# GeIL 5ns Chips
# CL 2.5 7-4-4 2T Timings
# 400(200x2)MHz
# 184 Pin Dimm
# 6 layer ultra low noise PCB
# The Geil has enhanced SPD for Dual Channel DDR motherboards.
# Backed by a lifetime warranty, this product symbolizes dependability.
So, what do I do when I try to OC my PC?
I set:
HT FREQUENCY to 4x
CPU RATIO to 9x
CPU FSB FREQUENCY: 230 or lower
AGP FREQUENCY: 66
CPU VID is 1.500v by default
Max MEMCLOCK: 166mhz
Memory timing: 2T
I was able to run the system at 235 FSB FREQ, but it wasn't stable. I tried putting the Memory timing to 1T, but then my PC only made god awful noises and I had to take out the battery on my MB..
I guess I can also mention that I have quite decent cooling on my computer:
-CPU is around 34 degrees
-GPU is around 48 degrees (it has that temperature when it's OCed a bit. I got a Gainward 7800 GS Bliss)
-Harddrives and MB is around 30-40 degrees as well.
Does anyone know what im doing wrong? I've googled some, and both my CPU and MB should be more than capable of some OCing!
Any help is appreciated. Thanks!
My equipment is:
# GeIL 5ns Chips
# 400(200x2)MHz
# 184 Pin Dimm
I set:
HT FREQUENCY to 4x
CPU RATIO to 9x
AGP FREQUENCY: 66
Memory timing: 2T
