- Dec 27, 2008
You're missing the point. It's not the motherboard that limits the speed your memory will run at necessarily, it's the CPU itself. The memory controller is built into the CPU (ICM, "Integrated Memory Controller"). The memory controller is rated for 1333 mhz. On the Deneb core CPUs like you have they will not run stable at 1600 mhz. You would need to upgrade to a Thuban core or a Bulldozer FX to be able to handle greater than 1333 mhz.
Besides that, there is essentially no performance advantage when you run memory above 1333 mhz. The present generation of CPUs, both AMD and Intel simply cannot use more bandwidth than what 1333 mhz memory will provide.
