Hi everyone.
First of all, sorry for my english !
My configuration are:
CPU: AMD PHENOM X4 955 BlackEdition
MOTHER: ASUS M4A785TD-V EVO
RAM: - OCZ DDR3 PC3-10666 / 1333MHz / Platinum Edition / CL 7-7-7 tim.
POWER: MODECOM CARBON MC 530W
VGA: ASUS GTX560 DCII TOP 1GB
My goal is to setup CPU at 3.8GHZ/3.9GHz with my memory at 1333(or better) stable.
Defaults BIOS settings give the memory speed at 1066 when autoconfiguration are active.
When i try to set it up at 667 or 800 MHz i have the pleasure to deal with a very unstable system.
Currently my memory working in GANGED mode - my current configuration is 3.79GHz CPU and the RAM 1225 stable, <-- thanks to CPU/HT and 1.89V for memory.
Can you help me set up BIOS for better RAM OC ?
My current configuration:
CPU/HT Reference Clock (MHz) [230]
GPU OverClocking [Auto]
PCIE OverClocking [Auto]
Processor Frequency Multiplier [x16.5 3300 MHz]
CPU/NB Frequency [Auto]
CPU Over Voltage [1.50000]
VDDNB Over Voltage [1.30000]
CPU VDDA Voltage [Auto]
LoadLine Calibration [Auto]
HT Link Frequency [Auto]
HT Link Width [16bit]
HT Over Voltage [Auto]
Memclock Value [533MHz]
DRAM Timing Mode [Both]
All timings are set to AUTOCFG !!
MemoryOverVoltage [1.89000]
Chipset Over Voltage [Auto]
SB Over Voltage [Auto]
ACPI SRAT Table [Enabled]
Probe Filter [Auto]
Advenced Clock Calibration [Per Core]
Unleashing Mode [Enabled]
Active CPU Cores [Auto]
Value (Core0) [-2%]
Value (Core1) [-2%]
Value (Core2) [-2%]
Value (Core3) [-2%]
Bank Interleving [Auto]
Channel Interleaving [Disabled]
Enabled Clock to All DIMMs [Enabled]
MemClk Tristate C3/ATLVID [Enabled]
Memory Hole Remapping [Enabled]
DCT Unganged Mode [Auto]
Power Down Enabled [Disabled]
Probe Filter [Auto]
Value (Core0) [-2%]
Value (Core1) [-2%]
Value (Core2) [-2%]
Value (Core3) [-2%]
