gldndragn2708
- Jun 28, 2018
Hello OCers,
I have a quick question about the BIOS on the MSI x370 Gaming M7 ACK. I am attempting to OC my Ryzen 1700 on this board but I am running into instability coming from the IMC.
When using Ryzen Master I can Successfully achieve a stable OC of 3.9 GHz @ 1.35v with SoC set to 1.1v VTT set to 0.685v.
When attempting to set a hardware OC in BIOS I am only able to achieve a stable OC of 3.4 GHz @ 1.4v w/ LLC Mode 1, SoC @ 1.2v w/ LLC Mode 1. (There is no VTT Voltage listed in BIOS) Any higher clock speed results in a slight jitter on the CPU (running AIDA64 Stability Test monitoring in Windows Task Manager). The CPU also is unable to reach 100% utilization.
My questions are as follows: Is there an equivilant option to the VTT Voltage in the BIOS for this board? And if not, How can I increase voltage to the IMC without a listed VTT voltage in BIOS?
System Information:
CPU: AMD Ryzen 7 1700 3.0GHz (3.7GHz Turbo) [YD1700BBAEBOX]
CPU Cooling: Corsair H100i
MB: MSI X370 Gaming M7 ACK (BIOS v.1.9) [7A35v19]
Memory: G.Skill Trident Z RGB 3000 16GB DDR4 (2x8GB) [F4-3000C16D-16GTZR]
SSD: Mushkin Reactor LT 250GB [MKNSSDRE250GB-LT]
HDD: WD Blue 1TB [WDC WD10EZEX-008N5A0]
HDD2: Toshiba 4TB [HDWE140]
GPU: Asus Dual RX480 8GB [DUAL-RX480-O8G]
PSU: Rosewill Photon 650w [PHOTON-650]
Optical: LG 14x BD-RW [WH14NS40-OEM]
Optical2: Lite-On 24x DVD±RW Super-Multi [iHAS124-14-OEM]
Wireless Network: Killer AC 1535 (Bundled w/ MB)
Case: Corsair Carbide Series Air 540 Silver ATX Cube [CC9011034-WLED]
OS: Windows 10 1709
Addendum: I am aware that I am pushing the limits of that PSU. Thank you for your concern but I am already aware of the issue there. just wanted to state that before receiving a million comments about it.
Any assistance would be greatly appreciated.
System Information:
OS: Windows 10 1709
