Ardamir
- Nov 25, 2017
- Patras, Greece
Hello guys, 2nd post here. I consider myself a seasoned overclocker with experience on various system configuration, so no I'm not a noob, this is a serious question . The question that I come here with, today, is about motherboards and RAM.
In my tests, I noticed that an MSI A320 Grenade that I was reviewing, managed to clock the RAM I was using considerably higher, than the previous MSI X370 Titanium I was becnhing with.
Now ok, this sounds a little bit unreal, but it's what happened. I used the same configuration (same CPU and same RAM kit) and both boards where updated to the latest possible BIOS (same AGESA too), but the budget A320 board managed to achieve a higher stable clock than the top-notch X370.
As far as I know the things that define the maximum RAM OC you can get, are ;
1. BIOS/AGESA version
2. Binning of the RAM DIMM's
3. Binning of the IMC
4. Voltages applied to both the IMC and RAM (lets not go into CLD0_VDDP, VPP, VTT and that stuff)
2, 3 and 4 are out of the equation since I used the same voltages, same RAM DIMM's and the same CPU, all of witch haven't suffered any degradation whatsoever which could affect the maximum achievable OC. The only thing that could explain that phenomenon is 1.
In my mind's eye, it really doesn't though. How can the lowly A320 mobo have a better BIOS than the "state of the art" (it's actually a really ****y mobo for its pricetag ^_^ ) X370? It's gotta be something about it, because the AGESA version was the same, Pi1.0.0.4C.
Is there something that I'm missing? Is it really just a ****ty BIOS? Is there more to a motherboard that affects RAM overclockabillity than the things I mentioned?
Even if the answer is complicated af, please do write it below, or point me in the right direction with a link or two.
Because atm the best explanation I got (from a friend), is that the Voltage controller of the motherboard (controlling the VSoC and VCore VRM) is responsible for this situation, thing which I consider being beyond stupid.
P.S Sorry if you find any mistakes, English is not my 1st language.
