- Nov 2, 2007
Hey diddeli ho!
Im a hobby gamer, and im hooked on Team Fortress 2!
The problem is that the game lags a lot. I want to run it SMOOTH.
My current gear is:
-AMD 3000+ (1.8ghz)
-2gb ram
-Gainward 7800 GS bliss (512ram)
-MSI K8N NEO2 Platinum
-Win XP (32 bit)
3dmark06 score: 3980 (Almost got 1000 more score just by OCing the GPU some)
A new and better CPU will make that lag disappear, I hope. Or is it my GPU that is holding me back ?
If a new CPU will help my lag disappear, which one should I get?
I have looked at some online stores, and these are my options:
1. AMD Athlon 64 4000+ 2.6GHz (150$)
2. AMD Athlon 64 3800+ 2.4GHz (115$)
3. AMD Athlon 64 4200+ X2 S-939 2.2GHz 2x512KB TRAY (150$)
Im not certain if my motherboard supports "X2", do I need some special MB for that CPU?
Link to my MB:
http://www.msicomputer.com/product/p_spec.asp?model=k8n_neo2_platinum
If I can't use the X2 on my MB, I have to go with either 1. or 2. If there ain't a huge performance difference between those 2, I'll just take the cheapest.
What do you recommend?
My current gear is:
-AMD 3000+ (1.8ghz)
-2gb ram
-Win XP (32 bit)
Link to my MB:
