nonono, not my stock clocks, but my card with stock cooling and voltageCheator said:My stock clocks for the x850 xt pe is 540/590. Don't know why yours are so high.
bobmanfoo said:nonono, not my stock clocks, but my card with stock cooling and voltage
nkcd said:This is a bone stock Sapphire X850XT PCI-E card sitting in my P180. I can't get the core to go over 533mhz or else it'll have artifacts and hangs my system during 3DMark03. Mem, I can go all the way to 621mhz without any problem.
What can I do beside cooling? I mean, even stock, I should get better result than that right?
Thanks guys.
mikeguava said:Either you have one of the worst XTs ever - or there is another culprit.
I have a feeling that the PSU might be the problem. I have experienced similar probs before, where an underpowered PSU caused clocks to go down the toilet.
Was the card new or used?
Did you try benching with higher clocks yet? Not too bad at all!nkcd said:This is the 3Dmark05 benching at XTPE clocks with my red system at Stock, all air, no OC no nothing, just the card. So freaking low
Free_Loader said:What are the settings for the test and are they the same as another score you are comparing against? Drivers and making sure you uninstall/install them properly cause a large variation in the score as well as the version of 3D mark you are using. I would expect a score of 12000 or so with that card, IMO......I had one myself.
nkcd said:This is 3DMark05. I'm complaining about its capability to OC. I don't know what's holding back this card or it's actually is the core itself.
Btw, I let ATL Tray Tool scan for artifacts and it starts showing 1 artifact at 535 core but didn't at 540?
