- Oct 20, 2005
Hello,
I have a very old Sapphire X800pro VIVO that I bought like 1½ year ago. I want some more vid power now, normally I would buy a new vid card but my economical situation isnt the best anymore so I try to overclock instead. The XT PE modd seems intresting
Okay, so I downloaded ATI tool, to test out...core/mem 519.75/558. And I ran "scan for artifacts" fine for 120 sec no error but then 76 GPU temp and rising!!! so I aborted and I will clock it down befor running any game.
Does ATI tool really show the right temp? How much can the GPU take before crash and/or failure? Does it have a fail-safe like CPU's?
EDIT
Even at stock speed it hits 76 degrees. Tops out at about 78 after 120-150 sec at 519.75/560.25
Is it supposed to have a temerature controlled fan?
EDIT
