- Thread Starter
- #21
Moto7451 said:Heres another idea I saw on The Screensavers. Make a circuit that just selects which drive is master and which one is slave by using a switch. That way you can use all your drives and it doesn't have any real effect on the system if you switch it during operation.
Its essentially a switchable jumper. If you wanted to keep it really simple, just have two DPDTs per HD and configure the jumpers that way.
yup, that will work too.. there's actually alot of configuration that can be made basing on the user needs... relays might come handy in other configurations...
