- Mar 13, 2005
Well posted my results, you got freeagent's attention, would you care to enlighten us with the knowledge that triggered the above.Maverick0984
@ Supershanks, I sure hope it doesn't take you 2.25v to get those to 1200Mhz...
DDR2-800 Ballistix chips can reach 1066 at 2.2v still with slightly looser timings. You shouldn't be recommending those to anyone btw. Unless by some chance your FSB for your CPU is at 600Mhz (which it isn't). Clock your ram back down, try to get to 1:1 ratio with the CPU FSB and lower the timings of the RAM. That is the only place where you might, and a strong might, have a performance boost. Running them at 1200Mhz buys you nothing, other than saying you are running them at that speed. There are no performance gains.
Again, unless you are actually able to achieve a 600FSB on your CPU. Which I assure you, you cannot .
Apologies to v8440 if it's a little offtopic, but throw away comments like the above can confuse newbies, hell they confused me.
