well yes i disable a lot of stuff in there regulary
not just drives.
but i use DEVCON.exe in a batch, attach a Icon to the batch, and click on the icon.
then make up a batch that swiches it off if it is on and on if it is off.
I shall explain.
after having found the devcon program, and not installing it
its a single executable , just drop in the sytem path somewhere like windows system32.
(it is different one for 32bit or 64bit systems)
it starts out in the CMD console thing. command prompt , dos prompt , Psudo dos console.
I learn how to use Devcon by typing
DEVCON HELP <-- which is the help for it
look at all the fun things you can do
there is a FIND, and a STATUS and DISABLE and ENABLE
i just happen to know what those mean
So first i look at the List with the * wildcard (everything or nothing)
DEVCON FIND * <--- the ALL wildcard
and there is every device in the whole computer OMG!
So time to find a Label for the device, some way that devcon will know what i am talking about.
DEVCON FIND S* <--- wild cards, gonna need them because of the crasy names
and there is everything that starts with S
Hey isnt this just like talking to the computer
DEVCON STATUS *Lightning*
and there is one of my hard drive arrays.
DEVCON DISABLE *HID* <---- this does the same thing as when you disable in the device manager
poof all the mouses and keyboards are gone .
OOPs ok lets not do that again.
DEVCON FIND C627s hard drive <------ this is me being funny
Ahh stupid computer
DEVCON FIND *WD* <---- this tries to find any device in the list that has WD in it
ok there is more than one eeek lets not disable all my hard drives, that would be bad.
DEVCON FIND *WD15EADS* <---- this restricted the above find , tuning out other things it finds via the wildcards
cool the one 1.5t , and nothing else
DEVCON DISABLE *WD15EADS* <---- this disables the device the same way it does in device manager
ahh crud, so much for that, Says Reboot required
DEVCON STATUS *WD15EADS* <---- find out if its disabled and done
Device is disabled
weird it doesnt do that when i did it manually in the device manager.
ok it is working, and in a batch i dont see that it asks for reboot, it isnt a requester pop.
If you want to give it a try, its rather fun, then i can show you how to get status, and batch it.
now say i have 3 WD15EADS, but i only want to disable One
I just provide Devcon with enough information, from the Wildcard , to insure that only One will ever be in that wildcard
DEVCON STATUS *WD15EADS-0P8B0* <----this has added more of the ID info from that Device, further identifying it.
you will see the whole names of any device after you find or status any of them
you know you have the ID in correctally if you can do a FIND or STATUS on them and they show up.
