- Oct 27, 2004
- Albany, NY
I have a fan from this page:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835345031
The specs are:
200mm
Dimensions (mm) 200x200x25mm
Current (A) 0.28A ±10%
Speed (RPM) 900 RPM ±10%
Air Flow (CFM) 148.72 CFM ±10%
Air Pressure (mmH2O) 1.26 mmH2O
Noise (dB-A) 27.5 dB(A)
Now, on Speedfan application, it is showing the fan RPM of a constant 720RPM. I have the fan plugged into the motherboard case fan header.
Now... +- 10% variance in rpm, would rate my fan at 810RPM and the absolute lowest., a far cry from the reported 720RPM.
Do I have a defective fan?
The specs are:
200mm
