- Jul 4, 2011
I'm having issues overclocking AND flashing my bios (altering the shaders from the 6950 up to 6970). I can't overclock using the AMD VISION Engine Control Center, or well, I can OC but when I do games crash no matter what I push the GPU and memory clocks to. I have this model of the 6950 http://www.newegg.com/Product/Product.aspx?Item=N82E16814131389 and it defaults at 800mhz for the GPU clock and 1250mhz for the memory clock. Even at 801mhz games still crash or 1251mhz games still crash. I read somewhere to increase the power control to +20% because I might be throttling the card but that didn't help at all. Next is the bios flashing. I didn't actually flash a different bios (meaning I didn't flash a 6970 bios) I just followed the tutorial here: http://verrytechnical.com/safely-unlocking-extra-shaders-in-reference-amd-6950-graphics-cards/ which essentially edits the shader amount in the current bios file that you have (is that what it's called?) and reflashes it. I've followed the entire thing and tried it with the bios switch in both positions and it doesn't work at all. Is this a problem with the tutorial (which seems to have worked for everyone else) or with my card, which already seems to flawed in the OC department (unless I'm doing that wrong as well). Thanks guys, hopefully I put this in the right spot :/
