First off I am an electrician so I know what Im doing when it comes to electrical wiring, and electrical theory.
Now that that's out of the way, I just built my first water cooled system, but what would that be without a way to quickly cut power off to the system in case of emergency.
My plan is simple, I want to run 2 14 gauge wires behind the back plate of my case and into the front 5.25" drive bay to where I have a switch I will mount to be used as a quick dis-connect.
Has anyone tried running 120volts through their case, I am not too worried about it, if I cross all data wires at 90 degrease it will cancel out any noise from the 2 wires. And the back plate should protect against any electrical field around the wires from getting to the motherboard or other devices.
Just curious if anyone tried this.
