- Jul 9, 2013
- Sadly Iran :(
Hi, i can say this is my first real overclock !
So this is what i did: I started heaven bench on windowed mode and started amd catalyst on right side of my monitor, As i increased the core my drivers gave not responding, My power was 20% and recovered at around 1130-1140Mhz, Then i made it back to default. Then i started to increase Memory clock and once i hit 1130Mhz my screen went white with some lines , I pressed some combos and they didn't work so i pressed the reset button and got here (Is that safe to do this?) My question is : I know i have reached my max clocks , But why did my cart get like this suddenly? I mean 1mhz lower its totally fine no weird things happening (I have never seen a artifact before so i may have missed it!) suddenly everything goes white? As i read on the internet it starts to show some dots or weird shapes at screen and then go like that, Mine just goes like that in 1Mhz from fine to this !
anyway i got 2fps+ and went up to 1220Mhz Memory - 1120Mhz Core. Not worth it at all I was just experimenting
And another question: if for whatever reason a person just instantly makes the core clock 1300Mhz with no voltage change, What will happen, Will my card fry? Or restart or something?
