So my computer currently has 8 fans. Here is the set up.
4 120mm fans up top. 2 underneath my liquid cooler, and two up top. All four are facing up to bite the air out.
1 120mm fan on the rear, blowing air in.
2 120mm on right case side, blowing out.
1 200mm on the right case side blowing air in.
Did this seem optimal for what I have? Or should I change them ?
Also should I run them through the connections on the liquid cooler, the fan control on the case, or the fan control I have installed, the sentry 2?
Thanks for the input in advance.
