- Jun 27, 2015
- Madrid, Spain
For my next build I would like to bite way more than I can chew (copper tube watercooling and wrecking a case). The thing is, I can´t choose a case.
My case dilema:
I really like builds where you can see everything inside. Thats why the format where the board is horizontal really appleas to me. For example I like the way that you can cut a window on the side of the Corsair 250D to see the GPU and enlarge the top window. I also like the HTPC format since everyting is seen top-down, however I haven´t found one of theese cases that I like and has the GPU all the way on the side like the 250D so that I can cut a window for it. Many of the watercooled HTPC builds have radiators outside of the case which I don´t really like. Also there are lots of 250D builds on the web, and I would like for you guys to follow along on a build that is unique.
What I would like to do:
I want to take one of those top mounted PSU mATX cases that are relatively narrow since they dont have a second section in the back for cable management and knock it on its side. Therefore, if you now look at it from the front the PSU will be in the back right corner, the IO will be in the back (duh), and the GPU will be on the left. However, the GPU isn´t that close to the left if I use an ITX board to put a window on the left (what used to be the bottom of the case if standing up). The top panel (what used to be the left side is now the top) would go away and I would add a whole glass window. What is also a pain is the feet on the side. Adding feet to the new bottom wouldn´t be and issue. As for the refrigeration I would cut out all the drive cages in the front and add a PHAT 360 mm radiator with push-pull in the front. Depending on the case I´m assuming that I would have to add usb, audio, and pwr/reset buttons somewhere else. It may be a good chance to cut out the protrusions that some cases have on the left where the old feet used to go and put that there.
Overall, I don´t really know if i´m getting way over my head on this or if I should just find an HTPC case that works for me and forsake the beauty of modding. It would be nice if you could point me towards certain cases or mods that have gone in this direction. Right now nothing is concrete since this is only in the process of brainstorming and soaking up the inspiration.
Thanks in advance!
My case dilema:
Thanks in advance!
