Good morning folks, I'd like your opinion on my current overclock. I have an Asus P5-K MB, E8400 cpu, which I overclocked form stock 3.0 Ghz to 4.0 Ghz. The system was tested with Prime95, for almost 8 hours, with max temps under load of 68/70 C, according to Coretemp. The cpu is cooled with an aftermarket cooler, on air. After the stress test, I ran the simulator with pretty much all sceneries I have set to max, which is something quite cpu intensive, and the average temp under load was around 58/60 C.
To reach 4.0, I had to increase vcore to 1.4, as per CPU-Z, overclock the RAM from 400 to about 460, with vdimm set to 2.0.
What do you experts think? Could I keep my system with these settings? The system is stable, it goes through POST with no problem. When no intensive program is running, temp drop to 45/47 C.
In the near future, I am planning on building a new PC, with maybe the next Haswell cpu, and liquid cooling, for better overclocking.
Let me know what you think, regards,
Enrico
Enrico
