I know a little bit about overclocking, but could really use some help on this one.
I recently decided to upgrade some parts of my computer, and adding more RAM was part of it.
I currently use a
- Gigabyte GA-P55A-UD3 LGA 1156 Intel P55 mobo
- 2 x 2 G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) timing 7-8-7-24
- Intel core i5 750 2.67
- Seasonic 750 watt power supply
So I have always been able to overclock my setup to 1600 on the ram, and 3.2 on the CPU without any problems.
Recently I added GeIL EVO POTENZA 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) timint 9-9-9-28
All ram works btw, I tested them.
Problem is...
Everytime I add the ram, and run all 4 modules, if I try to overclock to the previous 3.2 cpu and 1600 ram, I get an error on boot up and it kicks me down to 2.1 ghz on the CPU and 1333 on the ram.
I tried overclocking with JUST each set of rams, and they all overclock perfectly and stable without the other sticks installed.
Its only when all the ram is installed when I get overclocking errors.
Can someone please help me???
I currently use a
Problem is...
