- Dec 30, 2003
- Saint Cloud, FL
Who makes the best one?
Thanks
Thanks
FudgeNuggets said:Whoever's is cheapest. Usually Madcatz
jenko said:Avoid the madcats VGA cable like the plague its a reall piece of crap it has zero screening and the cable is just a few mm thick.
The best VGA lead is the offical MS one but it does cost more but its worth it, and it comes with a VGA coupler and a RCA to 3.5mm jack adapter.
FudgeNuggets said:Balogna, that's the same crap logic that store clerks use to sell Monster Cable's insanely priced stuff. You only need the thick and heavy gage stuff if you're running it long distances. The 3-6ft from your 360 to your TV/Monitor won't make a difference if it's a 20au wire or a 6au wire.
Kibokun said:How does VGA compare to HD on a TV? I've heard that I could use HD through VGA on a regular pc monitor.
-maddog- said:Would elite 360>hdmi-dvi adapterr>pc monitor work to give you 1080p digital?
