- Sep 21, 2010
This is probably the oddest behavior I've ever seen in a computer. It's a home built rig. The specs are:
AMD Phenom II 965 BE
Asus M4A79T Deluxe
4GB Crucial DDr3 @ 1333mhz
XFX Radeon 5850
OCZ Vital1ty 750w PSU
This is what happens when I try to boot my computer after school:
I'll press the power button and hear it beep, signifying POST, the light on the monitor turns from green the yellow and the computer sits there dormant. I hold the power button for four seconds to turn off the computer.
2nd try booting, I press the power button. It beeps (POST?) the light on the monitor turns green, the harddrive spins and then stops. The light stays green for a few more seconds and then turns yellow. I just press the power button at this point and it shuts down.
3rd try booting... same as the 2nd try
4th try booting, this is the odd one. I'll press the power button and either see the BIOS screen all fragmented, or I"ll see a black screen and then the Windows boot message saying "contiue system resume / delete restoration data and proceed to system boot menu" This would be relieving however theres a white screen tear going vertically up the monitor, when I press up on the keyboard to highlight continue the monitor flickers black, I hit enter and the computer does nothing. Hold the power button, fans stop I press again to boot a 5th time.
5th try booting.... The computer boots and the fans are noticeably quieter then they just were when I turned off the computer, the computer POSTs fine and boots windows like nothing happened. I can hibernate, restart and suspend all I want for the day and the computer will boot fine. This problem wont come again until I come to the computer after school tomorrow.
As you can see this is an extremely odd issue, I'd guess it's the motherboard since I just got it replaced; however the previous motherboard (same model) had booting problems and the computer would refuse to work for days on end. The only other part I RMA'd was the GPU, it had a defective cooler. I ran a MEMTEST and the computer passed 8 cycles at stock speed. Nothing is overclocked.
Asus M4A79T Deluxe
XFX Radeon 5850
