Hi,
I have a MkI Abit BX6 motherboard.
Originally it was running 320mb of ram and a 333Mhz Pentium II Processor.
Just recently I have bought 2 128mb PC100 RAM sticks and upgraded it to 512MB and a 1Ghz Pentium III FC-PGA processor.
The processor is rated with a 100FSB and 1.75v I have fitted a Soltect Converter (Slot1 to FC-PGA) and have fitted this into my system.
Everything seems to be fine except I can only set the CPU to 956Mhz using a bus speed of 100 and a multiplier of 8. I have contacted Abit to see if they do a bios update to support more multipliers. Also I get a cpu unworkable error message which I have disabled in the BIOS.
The problem I have is mainly to do with Hard Drive corruption. I am getting a lot of cross linked files etc since my upgrade and am wondering if this is related to my processor not running at full speed? This is under windows 98se
Under Windows 2000 this refuses to start producing an application as failed to write to a certain address. "service.exe has failed rebooting" before its fully started up. This same error message occurs on both my installations of windows 2000 which are multi booting on different hard disks.
What I wish to know is how do I cure this problem? wait for a bios update? Play around with ram timings if I can? or could it be corrupt memory and if so how do I identify the suspect chip?
If I do get a bios update because the cpu running not at its full speed are there any risks when I do the flash update because my cpu at an incorrect speed? I have done flash updates before
Thanks
Thanks
