I don't have a fan blowing on my ram, so what is the safest max amount of voltage i should put threw it 24/7? I am using the memory in my sig.... thanks for any replies
Depends on the ICs...If they are winbond, 3.3v should be okay, as these winbond rates most of their IC's to handle up to 3.6v. Any other brand, I say 2.8~2.9v.
it really depends on the ic's. some get way hotter then others, that's all. touch them with your finger while you are gaming. if they too hot to hold your finger on for 5 seconds then you need to turn it down or get some active colling for them.
