Notices
Overclockers Forums > Software > Programming Tips and Tricks
Forum Jump
Awesome new CPU stress utility needs feedback!
Thread Tools
Old 02-12-08, 10:49 AM   #41
asusradeon
asusradeon's Avatar
Quote:
Originally Posted by g0dM@n View Post
Well what if he wants credit for it?? someone else may take it and create their own OFFICIAL burn-in prog, no?
Well this is the same for ALL open source software, people could use the code and take credit for it...
__________________
Intel C2D T6400 2.0Ghz -- Dell Studio 1555 -- 4048MB -- Windows 7 Pro
AMD Athlon X2 4200+ -- Asus V3-M2V890 -- 2GB Kingston -- Windows 7 Pro
Intel C2D T5870 2.0GHZ -- Vostro 1510 -- 2048MB -- Windows XP SP2
ASCII stupid question, get a stupid ANSI !
asusradeon is offline   QUOTE Thanks
Old 02-12-08, 08:41 PM   #42
ShadowPho
ShadowPho's Avatar
Seeing as nobody's PC exploded, I tried it out.
Shot up straight to 80C, then my fans engaged at full. First time I ever heard the sound of fans over my music in my new PC .
Good job OP!
__________________
"Take only that which you can give"
Need Help? IM me! I want to help the OC community!
MainComputer:
E6400@2.69-4.0 gig RAM-8800GT
ASUS P5N-E SLI
ShadowPho is offline Heatware Profile   QUOTE Thanks
Old 02-12-08, 11:54 PM Thread Starter   #43
Nanerbeet
If you suspect the crash is not related to overclock, run it at stock speed, stock voltage just to verify.
If the processor overheats, it will hang or reboot. If the processor fails a calculation (such as memory address or branch mis-prediction), it will crash. Not exactly "built-in" error checking; its just that the elevated heat condition might help trigger a failure.
Nanerbeet is offline   QUOTE Thanks
Old 02-28-08, 06:16 PM   #44
esveezy
esveezy's Avatar
I can confirm that this gets my X3210 hotter than any other program I've tried - it is like TAT, only i works all 4 cores.
esveezy is offline   QUOTE Thanks
Old 02-29-08, 02:46 AM   #45
Blazing fire
Why don't someone try 2/4 old fasion P95 (red one) and orthors, both piority 10 and compare with this one? I'll post mine soon. All in all, you should get 3 different core temp readings.
Prime95- Core 1= Core 2
Orthors- Core 1= Core 2
Damage- Core 1= Core 2
I'll edit it afterwards if I remember.
Blazing fire is offline   QUOTE Thanks
Old 02-29-08, 01:13 PM   #46
Drinkyoghurt
Drinkyoghurt's Avatar
it's not doing anything for me, stock speeds and it's 23c, those are my idle temps! I get 31c load with orthos(yes those temsp are correct )
__________________
CPU:
Intel i5-2500k 4.7ghz 1.34V - M0b0:Asrock P67 Pro3 Rev. B3 - Ram:Corsair XMS3 1600mhz 7-8-7-21 1.63V - Cooler: Thermalright Ultra 120 Extreme - Videocard:Sparkle GTX 260 216 core 55nm -
14459 marks in 3Dmark06
Reboot: "Don't argue with idiots. They bring you to their level and beat you with experience."
rdrash:"I think Todd changes hardware more frequently then he changes his underpants."
Join the benching team and be part of the elite
Drinkyoghurt is offline   QUOTE Thanks
Old 02-29-08, 01:14 PM   #47
thideras
Banned Neckbeard Moderator
Premium Member #3
thideras's Avatar
Quote:
Did you....you know...run it?
Haven't seen an issue on any of my computers.
__________________
Desktop: Gigabyte Z77X-UD5H | 3570k 4.6 GHz | 32 GB GSkill Ares | GTX 570 | 180 GB Intel & 2 TB total | Arch Linux and Windows 7
Main server: 30 TB raw disk | 2x Opteron 6134 | Asus KGPE-D16 | 128 GB RAM | IBM M1015 | CentOS 6.2
VM Server: Dell R710 | 2x E5645 | 288 GB RAM | 8x 300 GB Velociraptor | Xen Cloud Platform (XCP)
"That's not overkill, or a lot. That's just thiderastic." -txus.palacios
Current projects: Rackmount Overkill (New) | 30/45 hard drive server
Articles: Rack Mounting 101 | Dell Perc 5/i Throughput Benchmarks
Past projects: Software RAID | The Dragon Case
My Website
Want to talk directly to all the moderators at once? Call the Mod Hotline!
thideras is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 02-29-08, 01:18 PM   #48
Drinkyoghurt
yes...I .... did
well, atleast it said "running for xx:xx amount of time"
__________________
CPU:
Old 02-29-08, 01:20 PM   #49
thideras
Premium Member #3
thideras's Avatar
yes...I .... did
Why....are....we....talking....like....this?
Did you check the menus just in case it didn't actually start? Like set it to two cores and back to 4, etc.
__________________
My Website
Old 02-29-08, 03:51 PM   #50
Drinkyoghurt
it works now, but it's only 1c hotter then orthos @ stock speeds. I haven't tried OC'd yet
__________________
CPU:
Old 02-29-08, 04:11 PM   #51
thideras
Premium Member #3
thideras's Avatar
Something isn't right, you sure you its at 100% load?
__________________
My Website
Old 02-29-08, 04:33 PM   #52
Drinkyoghurt
yeah, but this is only @ stock, it gives a 1-2c difference, not more..don't know about oc'd though, should be a bit more delta t in there
edit: finally a delta t of 4-5 c
__________________
CPU:
Old 02-29-08, 05:45 PM   #53
Blazing fire
lol....what...a...weird...way...of...talking.
Old 03-17-08, 11:33 AM   #54
Hazaro
Hazaro's Avatar
Bump for this beast.
__________________
2500K @4.2GHz, P8P67 PRO, 8GB G.Skill Sniper, RocketFish Case, 2x 6950, X750 PSU, TRUE120
Hazaro is offline   QUOTE Thanks
Old 03-17-08, 04:56 PM   #55
RJARRRPCGP
Quote:
Originally Posted by thideras View Post
Same here, it just closed or it hit an issue. Seems like it has built in error checking.
Probably no error checking if it disappeared.
__________________
Asus Maximus II Gene- Core 2 Duo E8400 @ 3.6 Ghz (450x8.0)
-ICH10R
- eVGA GeForce 9500 GT-Fortron FSP500-60GLN(80) 500W PSU
" holy cow!! you find a rat in there too!?!?!? " -turbohans
"Reinstall winders." -jivetrky
"I think I am going to need another coke before I start this up." -cadman420
"Soon Windows will be 50 gb! lololol" -Tokae
"NOT FOR SALE IN CALIFORNIA."
RJARRRPCGP is offline   QUOTE Thanks
Old 03-18-08, 07:13 AM   #56
Nebulous
Seņor Senior Member
Nebulous's Avatar
10 Year Badge
I used to use Toast back in the skt A days, lol. Dam this is an old proggy. Used to put some serious hurting on those Bartons.
__________________
<MEGA-O>
Gigabyte Z77X-UD4H / i5 3570K@ 4.5Ghz
16GB GSKILL Sniper F3-17000CL11D-8GBSR
XSPC Rasa Black / RX360 / MCP-655 / MCRes
OCZ Vertex III SSD 120GB / 2x Seagates 500GB~Raid-0
Diamond 7870PE52GDD Ghz Edition HD 7870+H80
Sony AD-7220S / Lite On LH-16A1S
SilverStone Zeus ZM1350 1350w
CM Cosmos 1000 / Win7 Pro x64
Samsung LN40A550 40" HD TV
** Under TITLE II, SECTION 210.340 it is legal to overclock **
Nebulous is offline Heatware Profile   QUOTE Thanks
Old 05-08-08, 08:44 AM   #57
Calmatory
First of all, sorry for a bump. :P
Prime95/Orthos are far from best CPU burning programs. For example while I get 70 C from Orthos, I get well over 80 C from S&M. FPU unit heats the A64's well.
Had to register here, just to post this!
Calmatory is offline   QUOTE Thanks
Old 05-08-08, 08:26 PM   #58
Diddyu
Diddyu's Avatar
Ive been using this for a while to compare temps and to burn in TIM, but i didnt know who made it. Not that good for stability checking, but does a fine job at cooking the chip.
__________________
Mobo: XFX 680i LT
CPU: Intel Q6600 G0 @ 3.8 ghz
Cooling: Apogee GT + MCW60
RAM: OCZ SLI Ready 6400 @ 1000mhz 2 x 1gb
Vid: 2x EVGA 8800GTS 512 (g92) @ 812/1035/2020
Case: NZXT Lexa Black
PSU: Ultra Xfinity 600W
3dMark06:18356 marks
Diddyu is offline   QUOTE Thanks
Old 04-17-09, 12:52 AM   #59
zzzzzzzzzz
I preferred Core Damage when it did not require running an installer to install the program.
Please have a version that does not require the use of the installer.
zzzzzzzzzz is offline   QUOTE Thanks
Old 04-17-09, 01:02 AM   #60
ziptieboy
Holy thread resurrection, Batman!
ziptieboy is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
