QuietIce
Disabled
- May 7, 2006
- Anywhere but there
If you get even one error in MemTest you've got a problem. 181 or more is definitely not good ...
Can you post a screen shot of your events like konchus did?
i installed sp1 and all is well
Does CBS use Silverlight, too? You might check to make sure that's updated. I've heard it's buggy at best, on some systems, and I've had an occasional problem with it myself (Netflix), though not the same as yours ...
That's got to be some kind of driver conflict. If P95 (Blend, I hope?) passes for hours on end then I can't imagine it being a hardware problem.
When you swapped drives did you do a clean install, then update Windows (to SP1), then install drivers, then the streaming apps?
Edit
And just to reiterate - this is a new build and not OC'ed in any way?
You didn't swap hardware (except the HDD) from another build and then use the same Windows installation?
What other programs do you have installed?
do you have the onboard video disabled in the bios?
Thank you. Post edited to include information on Event 59 when using Win7. Nothing "official" (no KBxxxxxx) from MS on it, though ...That appears to be irrelevant for Windows 7 and Windows Vista.
Appears to be for XP.
