Good morning
I'm trying to understand how 10th gen Intel should be overclocked. My goal in the first part is not to overclock but to understand basics and I have questions related to it so I have good starting point. I've read a lot of articled about how to overclock but everything is in my opinion difficult when You need to start doing it because everybody have different mainboards, different names in bios of similar settings. Ok but first some basics that I have problem with...
1. Where to find in Intel specs what are save voltages for CPU. I have 10th i7 10700KF to play with and I just can't find on Intel specs what is default voltage for this CPU. Looking at different models there is also totally no info about it... I'm trying just to understand what is correct vcore value. Reading from HWiNFO64 value from Vcore shows totally different value than in BIOS. Also Intel XTU is showing another different value from sensors and I'm quiet lost here. I was expecting Intel XTU will tell me what is default value for this CPU and this software is telling that this value is "default".
2. I'm trying to understand my LLC in my MSI motherboard. Currently the setting is set to AUTO which don't tell my anything. But to understand it I need to know where to look for reliable Vcore readings in idle and full load. And this is totally not obvious as I described in 1st question. Why for example in HWiNFO64 Vcore is showing me in idle ~0.833v and during load (avg) 1.255v. From this I can't say anything about this AUTO mode in LLC. From my understanding IN IDLE we should have larger Vcore than IN LOAD and here is totally different. Or maybe Vcore is showing something totally different. I have MSI MEG Z490I UNIFY. I many different programs I see totally different values:
Values IN IDLE
HWiNFO and CPUID CPU-Z MSI Vcore = ~0.833-0.980V
BIOS Readings Vcore: ~1.044V
Intel XTU VCore: ~1.22-1.23V
Also what is in the BIOS:
CPU SA Voltage which is set to 1.050V
CPU IO Voltage which is set to 0.942V
Trying to understand all this relations. The goal for now is to understand what AUTO means in LLC and how it works on my motherboard and to set some specific Vcore in bios instead of auto so I will have some point of reference... I was reading CPU data sheets but man there is so many pages in this PDF's but after one hour I didn't find anything about recommended factory vCore values...
Looking for support and good day
Cheers.
Values IN IDLE
Cheers.
