He bought OEM, doesn't have a stock cooler.
Just get the Hyper212+, it'll take you to 4.5 at the least. If you don't want to run it that high, then it runs cooler and it's all good. It's by far the best budget cooler out there.
Apparently the silver arrow does provided better cooling by 1 C
Archer, there are some things that FrostyTech does that I don't consider good testing technique. First, they are testing with a synthetic heat load that doesn't really represent a modern processor all that well, IMO. Second, the max load they put on the heatsinks is 150 watts, which isn't crap compared to what kind of heatload modern high end overclocked processors put on a heatsink. And last of all they don't test in a working system inside a case, which completely ignores any flow rate variables a heatsink might encounter inside a case like 99% of the people would have their system mounted inside.
That is why I test inside a case, with a real system and why I have my test system overclocked enough to have a 200+ watt heat load applied to the heatsinks during testing.
