ok ill update after I get this bird flying straight
Brolloks I set bios to 8x450 1:1 = 900mhz 5.5.5.15 (this is ddr8500) should do 1066mhz at 5.5.5.15 with np.
I set cpu voltage at 1.5v
at bootup: (no load)
system temp 35c
PWM=46c
core0= 41c
core1= 40c
GPU core= 46c
all other voltages are stock right now maybe others need a boost?
When I run ORTHOS: "stress cpu with gromacs core"
Orthos doesn't even error out the mouse cursor freezes and the system just shuts down and reboots after about 10 seconds or less, so I pushed it to 1.51v and tryd again, got the same results, just got out of the bios right now and pressed on at 1.52v and going to run orthos again LOL this time Ill try and see what the temps are when it shuts down, I think it was at 60c last time, hopefully I don't get
OS file corrupted, I searched cpu section and most people I seen in this voltage range are running water or some hard core cooling I have an arctic cooling freezer 7 pro and good airflow (no water)
At what point should I stop pressing this vcore
I may lower it back to 1.5 and up the mch some? what do you suggest?
kinda buggers me I seen alot of folks at 1.41 at 3.6ghz on air also but maybe not this chip....
