For anyone interested I've created the chart with data from the article. The lower is the dot - the better is the fan
https://1drv.ms/x/s!AhIwJHZ40ocwoqFn_wPGlWkbgwt9RA
Btw it would be great if articles included some kind of raw data used in them
I was still listing fans alphabetically then. Here is my most recent review. The fans are arrayed in order of the center CFM -- through a rad or through a filter. The Yate Loons are loud at highspeed, not so loud at lowspeed. They are so cheap that I bought those four to serve as replacements for my daughter's rig. So far, the original is still going strong. If you buy Yate Loon fans, get two: one may click and they sleeve bearing fan won't last forever. In fact, at six years, my daughter's fan is getting long in the tooth for a YL fan. You would not normally expect one to last this long. I don't recommend M or H but L is 1000rpm -- about right for a case fan.
Now, PWM fans are what you will use on rads. Too bad YL doesn't make those.
I've never noticed but good info to know. I usually buy the high speed but run them at low to med speeds, probably 7-10v. Maybe that's why mine have lasted so long. I generally only turn them to full speed when trying to max or bench for a short time.Your motherboard is using voltage control, which is fine. Just be aware that many fans click when they run at significantly below 12 volts.
I think this is a wonderful pickup. I have looked at be quiet!'s website. Only 92mm and 80mm Silent Wings are still available, and they are 7-bladed but a photograph shows 9-bladed fans with skinny blades. So I can no longer tell what I tested. They are fans that came with an R5 case, but they are making the R6 now . . .This article mentions Silent Wings 2, but in the graphs Pure Wings 2 is listed. Should that say Silent Wings 2 in the graphs?
