Hi all, new here appreciate the hive minds help!
A bit of what has happened first:
So yeah I assembled my 1950x machine, unfortunately only starting to read about the issues with the cooler once it didnt seem to work.
Yeah its stupid, but the issue the 1st gen liqtech has isnt common with other AIOs afaik and I only saw the great reviews before, esp gamersNexus one. Also there isnt really an alternative. I had trouble with AIOs before so I was anxious though.
Anyway, 1st time turn on my machine, LED on the pump lights, fans spin, but pump block heats to 70C instantly. After a couple of more try I had to admit to myself Im ****ed.
This is when I started reading up on the pump on newEgg Amazon etc and by now half of the reviews are about the clogged up units.
Didnt see a point in returning it, I guess after waiting who knows how long I would get a same faulty unit.
I decided to disassemble.
A word of advice to anyone who tries this product: Before you install take the unit to your bathroom and slowly open one or both of the drain ports and let out pressure. As far as I know these aios arent designed to withstand any kind of internal pressure right? Like maybe at very high temp there could be some change in the fluids volume but negligible?
Anyway mine had such massive pressure in it it squirted fluid 10 meters away when I opened it. After complete disassembly I saw that one of the fluid routs were completely blocked so thats why it wasnt cooling at all.
I cleaned it out removed the minor amount of corrosion. I bought some aalpha cool clear ckc fluid because its adwertised that it prevents(not completely I guess) mixed metal or galvanous corrosion.
Tested the pump dry it was running, tested the rads they werent clogged heat up nicely everywhere, left it to run to see if it def didnt leak.
My rad is inside the case with fans pushing through it.
Reassembled, applied paste accordingly and now it runs.
My question:
I did a 4Ghz oc with 1.4325V and the system was super stable and super fast. The problem is the temps were around 80C and fans going on max on full loads in Arnold or cinebench.
I saw a lot of people have 50C with this cooler at 4Ghz or at least I think. So I guess there must be something wrong here. One tricky thing though is I saw in the comments for this vid:
For asus mobos there are settings that offset the Tdie temp readings by -20C. I hope the people getting low temps with 4Ghz isnt because of this?
Anyway:
Could it be the fluid?
Is it possible that the pump is week or faulty after all?
Or is this what the enermax is capable of?
I have great temps at stock speed so the unit is working somewhat. Im running the pump from a molex conn. so it should be on full power constantly?
Anyway let me know if need more info, any help is welcome! Thanks
My question:
Anyway:
