Hi everyone. I'm planning my 1st WC build in the mentioned above (thermaltake t81) case and have few(plenty) of questions.
I've actually read a lot of the tutorials, but most of them seem outdated and also I didn't find any information about flow planning.
I have i7 5820k (a bit overclocked) and 980 ti to cool, but I wanna make a build to be capable to watercool one more GPU.
I'm not in extreme overclocking, just gaming, so AFAIK I don't need to focus on the performance, most probably it will be sufficient anyway => I'm trying to focus on silence.
Rads:
what I've understood about rads from all of the reviews: the bigger=the better. Thick with low density is the best choice. In my case i't is possible to install 140x3 rad in the front part (if I remove HDD buckets), so I've selected Alphacool NexXxoS Monsta Triple 140mm Radiator - 80mm
But I'm not sure at all if i need more rad(s) and where. Here are two sketches with options, that I'm trying to select from.
In the first one lower rads will restrict the airflow for the front rad, also the only possibility is to install 2x120 rads (1x 240 is not possible to fit). And even with 2x120 there is very restricted space between the front rad, lower rads and PSU. Advantages are: big common surface of rads, positive pressure inside of the case, so almost no dust issues.
Second option: upper rad still restricts the airflow, but not so much and there's even bigger common surface. Cons: No way to create positive pressure inside of the case, so dust issues, no air to cool other components and maybe? it's gonna affect the cooling, cause no air-no sufficient flow=?no heat dispersion.
There's also a way to remain with only one rad, but I'm not sure if it'll be enough for the system.
Fans
Right now I'm using Noctuas for my air cooling, but I've never met them as a suggestion for water rad, so I'm quite not sure.
Tubing
I want acrylic pipes,, Ilike everything to be in order, have no experience with them though, but I guess, that if I buy 4 times more pipes, it's not gonna be an issue. Also i'd like to swithc to copper pipes later (just for design), but this may be possible only after the build with the acrylic ones is ready. 12/10 mm woild be perfect (if it's enough).
Fittings
Have no idea which ones are good
Waterblocks No issues here (I guess?) Just select a trusted manufacturer for my hardware.
Reservoir
pls suggest something small and pretty
But the main question is : What is the best way to locate the rads?
p.s. I'd also like to make a custem leak detection system based on Arduino, moisture sensor and a hydrophobic cable (should contain two wires divided by hydrofobic material -e.g. cotton). Has anybody any idea where to get such cable?
p.p.s sorry for the mistakes, english is not my native language, and thx in advance for your replies.
Rads:
Fans
Tubing
Fittings
Reservoir
