bajanknight
- May 19, 2013
Hello All,
My 1st build has gone as planned up until reviewing temperatures.
Fractal Define Mini 3
Biostar Hi Fi A85S3 (Latest BIOS)
AMD A10-5700
Noctua NH-L9a / NT-H1 Paste Used
8GB Kit (4GBx2), Ballistix DDR3 PC3-14900 (1866)
Seasonic SS-300ET
Plextor M5P 128GB SSD
ASUS 24X DVD Burner
Windows 8
The below screen dump shows the variety of Temps runing p95 Blend on all 4 Cores (No Overclock/Ram at 1866), The one that is concerning is the highest temp. It would appear that AMD Overdrive may indicate throttling. I have read that 70c Should be the max (By Scale not Degree) for the A10-5700.
Can anyone indicate what they would think, is it a wrong number or is this what it looks like when you don't get a good cooler paste bond to the CPU?
Note That the CPUID HWMonitor A10-5700/Temprtr Package(82c) shows ~Same as CoreTemp CPU#0 and about the same as AMD Overdrive's individual core temp readouts. The Temperature Monitor in the upper left corner is from the Biostar Website, I think it grabs Bios Temps and would seem the same as the temps I pull from the actual BIOS, although a little cooler since Windows is controlling things.
I have read that the CPUID "Package" is supposed to be the sensor under the CPU Socket? Since this sensor would have to be a component of the Motherboard I would have expected it to have been listed within the Biostar drop down instead of the A10-5700 drop down. Since the temps are more matching what AMD Overdrive are listing for individual Cores it has me guessing that maybe "Package" is in fact internal CPU Core Temp...
Any Advice figuring out what is what would be great!
AMD A10-5700
Seasonic SS-300ET
ASUS 24X DVD Burner
Windows 8
